This documentation site has been frozen, no further edits will be made here!
The new RouterOS documentation site is available here: https://manual.mikrotik.com/docs/introduction/
In This Section:
After successful RouterOS software installation (if it was needed) it is time to access the router for the first time. There are various ways how to connect to it:
Normally you connect to the router by IP addresses with any telnet or SSH client software (a simple text-mode telnet client is usually called telnet and is distributed together with almost any OS).
If no IP or MAC connectivity is available, some devices allow connection through a serial port (DB9 or RJ45, depending on the model);
  • No labels
